99 mc 3100 no spark
Old Apr 2, 2011 | 06:33 AM
roughgar's Avatar
Angry 99 mc 3100 no spark
hello can any one please tell me why I am not getting any spark at all from a 99 mc that has sit for a while?coil pack shows to be good getting signal to cam sensor?
Old Apr 2, 2011 | 06:12 PM
Caffenated1's Avatar
How are you checking for spark and what all did you check? Maybe this will help me understand a little better. The reason i ask is because if your checking the plugs against the engine block, it could be bad plugs/spacing.. If you're checking the end of the wire off of the top of the plug, it could be bad wires.. If you're checking the end of the wire closest to the coil pack, it's possible that the coil pack itself is shot. Even if it's a new coil pack, it's possible you have a dud. (it's happened to me in the past.)
Old Apr 3, 2011 | 06:13 AM
Welcome to the Monte Carlo Family. Sorry to read about your problem....Please post as much information about your problem as you can...We only have your posted words for our expert/tech/experience members to help with your problem.
Look forward to your update & additional information...
Example: How many miles on your Monte ? Are there any modifications ? What has been replaced ?
When was the last time it was running (properly) ? etc.
Good Luck
Old Apr 19, 2011 | 07:34 PM
7498MonteCarlo's Avatar
Photobucket
Monte Of The Month -- August 2010
Does it eventually start after sitting for a few minutes?
Mine did that. Not start. Wait 5 minutes. Start.
Long and expensive story short...it was the anti-theft module behind that glove box that cots $5 from the junkyard to replace.
Old Apr 19, 2011 | 11:59 PM
nitehawkjcb's Avatar
Did the motor turn over at all? If so, and you're sure it's no spark, it could be the cam sensor, crank sensor, ignition control module, coils, dead spark plug wire(s)
sickofsoyo
Jul 13, 2008 03:44 PM
black04monteSS
Jun 29, 2008 02:45 AM
dohc v6
Nov 25, 2007 04:14 PM
vita
Oct 15, 2007 08:56 PM
