Need to change brakes...
Well if you did not thoroughly degrease and really clean the calipers very well eventually spots of paint will begin flaking off the calipers. But then I do some very aggressive braking ands get the brake system pretty hot. I speaking from experience and I did not think the first cleaning was half assed, used a cleaner and High temp Caliper paint and still had spots flake off on the rear calipers.
I think the 6th gen's rear brakes are a stupid design. Why couldn't they put a normal vented rotor on the rear instead of a warp-prone thin disc with a dumb drum e-brake inside? These are supposed to be sports cars, right? Not a Kia.
I know the OP may be all set with brakes, but I used these on the '01 and it stoped on a dime
Summit Racing SUM-BR-62055R - Summit Racing® Extreme Performance Cross-Drilled Brake Rotors - Overview - SummitRacing.com
Summit Racing SUM-BR-62055L - Summit Racing® Extreme Performance Cross-Drilled Brake Rotors - Overview - SummitRacing.com
Summit Racing SUM-BR-62058R - Summit Racing® Extreme Performance Cross-Drilled Brake Rotors - Overview - SummitRacing.com
Summit Racing SUM-BR-62058L - Summit Racing® Extreme Performance Cross-Drilled Brake Rotors - Overview - SummitRacing.com
with these Hawk PAds
Hawk Performance HB360Z-670 - Hawk Performance Ceramic Brake Pads - Overview - SummitRacing.com
Hawk Performance HB359Z-543 - Hawk Performance Ceramic Brake Pads - Overview - SummitRacing.com
Holy ****! Those are nice brakes. Way above my pay-grade tho. This is my 1st car, so im learning as i go. Can't really tell the diff' yet.
But cleaning the brakes helped alot, def' don't hear screeching anymore.
Repair Guide: How to change your brakes and rotor.
Shandley
FWD Tech Guides '95-'07
30
01-01-2018 07:59 AM
7th Gen ('06-'07): Help me change my brakes please!
Tahj Mahal of Atlanta
11-27-2014 07:18 PM
dcnaser
03-25-2012 07:40 PM
