6th Gen ('00-'05): My v6 03 monte ss dosent blow heat
Old Jan 3, 2021 | 11:55 PM
Lucas Love's Avatar
Default My v6 03 monte ss dosent blow heat
Okay so my car wont blow out anything it kept going in and out id slap the dash somtimes work i checked my blower motor its fine i changed resistor still nothing iam thinking its the switch the only way i can defrost my front windshield is driving fast so there is what just not moving i think its the switch but iam broke and am starting a new job...i heard u could do somthing so u bypass the switch so it's on full blast or off is that true i just need heat till i get this first check please helpp
help my baby lol
Old Jan 4, 2021 | 08:03 PM
USPatriot1963's Avatar
I have your solution. The selector switch that controls face, face/feet, feet and defrost operates via engine vacuum. This vacuum comes from a thin hard plastic tube that runs off the back of the engine. This tube is held against the firewall by black plastic clips. Start at the back of the engine and look for a plastic line coved in a ribbed plastic sheathing installed at the factory. The tube winds around the back of the firewall, over the top and to the left of the left strut tower mount(passenger side), then winds in front of the battery and into the wiring harness where it is routed down inside and under the glovebox to the vacuum reservoir/ball. On the vacuum reservoir, there is a small vacuum line which runs to the selector switch we mentioned. Lets start with the easiest first: Open your hood, find the black plastic line against the firewall. Remove it from the plastic clips then run your open hand the entire length of the line from the engine to where it disappears into the wiring harness. If you find a break or crack in the line, there's your problem. If not, you will have to pull the glove box door and the panel underneath it to gain access to the vacuum reservoir and the selector switch. Good luck. Contact me it you need any further help.
skeeter 26
Apr 5, 2019 08:03 PM
koltman889
Oct 31, 2017 06:33 PM
mr markuSS
Aug 18, 2016 09:57 PM
Hailey2014
Feb 23, 2016 07:43 PM
mcarloss04
Nov 21, 2005 11:38 AM
