mutiple guage panel questions
Old Jul 13, 2010 | 12:59 PM
HPNOTIQracing's Avatar
Default mutiple guage panel questions
1. the trac control off light and the brake light are on all the time. they are in the same section of the instrument panel. this is an 00 mc ss.
they both came on at the same time after no incedent. doesnt seem to be causing any issues except i cant turn the TC on and off it seems to be off at all times.
2. it keeps saying time to change oil even tho i did. is there a way to reset that?
3. it saying i have low tire pressure even tho i dont. is there a reset for that or is it an issue of some sort?
Old Jul 13, 2010 | 01:05 PM
nyislanders's Avatar
As for the "Trac Off" and "Brake" lights being on, check your brake fluid level. I was low on brake fluid, which caused both of those lights to go on.
Old Jul 13, 2010 | 04:37 PM
thanks ill check that
Old Jul 13, 2010 | 06:33 PM
RocknSS04's Avatar
Your oil change and tire pressure monitors are reset using your radio settings.
If the brake fluid isn't low, you have either 1 of 2 problems. Either a speed sensor is bad in a hub, or PROBABLY you have a bad (dirty) connection from the speed sensor.
Old Jul 14, 2010 | 06:07 PM
Most of the time its a dirty connection though. So dont go buying nothing till you know for sure.
04MonteLS
Jul 20, 2006 11:05 AM
01whitess
Jan 5, 2006 06:53 PM
big green dog
May 12, 2005 12:04 PM
the4thlast1
Apr 26, 2005 08:41 PM
mghtymonte
Jul 30, 2004 03:29 PM
