7th Gen ('06-'07): Moonroof help please!
Old Mar 6, 2015 | 08:26 PM
ChevygalSS's Avatar
Default Moonroof help please!
Bought an 07 SS a month ago and the moonroof has never worked. According to the dealer it worked when they got it (whatever). The switch makes no noise when pressed in either direction. Is the switch bad or the motor? Where is a place online I could purchase the part inexpensively? Thanks for your help!
Old Mar 6, 2015 | 10:47 PM
just a guess here but you might want to check to make sure the Power is hooked up to it. try the fuse panel or if you can check the wire to the switch to make sure it didn't come loose. I had that happen on a car once. Hope it helps.
Old Mar 6, 2015 | 11:45 PM
ChevygalSS's Avatar
Thank you for your reply! I should have mentioned I checked the fuses and the wires, still getting the hang of this forum thing lol
Old Mar 8, 2015 | 08:04 PM
ohara's Avatar
You can probably pick up a used switch at a local junk yard, or rockauto.com will more than likely have a new switch you can purchase
99MonteZ34
Sep 21, 2010 08:23 AM
Blue_wolf
Feb 8, 2009 10:51 PM
DebbieJ
Oct 1, 2007 12:05 AM
sirmarsh
Jul 25, 2007 11:30 AM
wiz kidd
Mar 27, 2007 12:55 PM
