sunroof/moonroof stalling
Old Apr 15, 2008 | 08:37 AM
99MonteZ34's Avatar
Default sunroof/moonroof stalling
Hi There! I am new to this site although my Monte isn't new.
Yesterday I brought my Monte out of winter storage (not heated) and the first time I used the sunroof/moonroof it opened fine but stalled upon closing.After some time passed I tried it again and was able to jog it back and forth and it would stall at various positions while closing but would not completely closed.
Could someoneexplain this behaviour (or even just make a suggestion) so that I may repair it?
bfn
Old Apr 15, 2008 | 08:58 AM
rysZ34's Avatar
Default RE: sunroof/moonroof stalling
Your motor might be going bad...If you need it closed, pull the front of the headliner by the switch to expose the motor and there should be a torx bit, just turn that...it is a manual override. Unless for some weird reason our cars (I Have a '99 Z34 too) has to relearn something like the 00+'s do...
Old Jul 6, 2008 | 12:45 AM
99MonteZ34's Avatar
I should look for tumbleweed emoticons; it has been that long since I posted here.
Thank you for the info and suggestion rysZ34.
The gears inside the motor were jamming. I 'simply' pulled one out of a 97 Lumina at a wrecking yard and paid $30 instead of the OEM price of more than $400.
Old Jul 6, 2008 | 09:05 AM
rysZ34's Avatar
awesome. I'm glad that you were able to save some money by doing that.
Old Sep 21, 2010 | 08:23 AM
WVSuperSporter's Avatar
I was having same problem with my 2004 Monte SS, another thread mentioned a need for the sunroof to "relearn" the stops. Following the recommendations there, force-jogging if necessary, I ran the roof open and closed 5 or 6 times straight. It started working like new after that...
Mr.Monte
May 11, 2012 02:11 PM
Ricks 2006 SS
Jun 25, 2011 08:36 PM
Blue_wolf
Feb 8, 2009 10:51 PM
DebbieJ
Oct 1, 2007 12:05 AM
ckerdflag
Jun 1, 2007 09:59 AM
