6th Gen ('00-'05): 2003 mcss
Old Mar 8, 2015 | 03:45 PM
jcoeracing97's Avatar
Angry 2003 mcss
I've lost all lighting on the dash except for turn signals and warning lights. Instrument lighting, radio, gear selection and HVAC lighting all went out at once.
I've checked the fuses and they appear good. Bad ground perhaps?
Old Mar 8, 2015 | 11:41 PM
JC Colon's Avatar
Bad Ground, Bad Radio, Bad BCM, Bad Harness. There are several possibilities. Does your Alarm work? Door locks, Dome Lights? Knowing that could help narrow it down!
Old Mar 9, 2015 | 01:40 AM
Habbibie's Avatar
I remember that happened to someone I knew before. Same problem on a trailblazer, in the fuse box under his hood was a 100amp fuse that is different from the others it's screwed down by two screws on opposite terminals, it connected lines heading directly to the battery, it was I think I $30-35 fuse, we did the swap with a new one and lights lit up again. Not sure if our montes have this same fuse but once other tech gurus in this forum read my post I'm sure they'll know what I'm talking about exactly and they can chime in and which fuse is it exactly and how to locate it.
Old Mar 9, 2015 | 01:42 AM
Habbibie's Avatar
it was either a 100 or 115amp fuse I am leaning more toward the 115 for some reason I remember it's amperage struck me as something different from the rest
Old Mar 9, 2015 | 09:38 AM
The items that work: dome light, warning lights, DIC, turn and hazard signals, locks, windows, auto-dim on mirror
Items that don't work: Instrument lighting, map lights, radio and HVAC
lonerider
MCF Website Problems & Issues
Apr 2, 2014 02:58 PM
NASCARRICH
Oct 17, 2009 05:50 AM
kpssmonte
Mar 19, 2007 07:25 PM
rideHI
Dec 7, 2006 11:48 AM
Hunter_ST
Jul 20, 2005 11:38 PM
