Monte Carlo Blower Motor
Old Jun 1, 2025 | 06:32 PM
0MonteCarloSS4's Avatar
Default Monte Carlo Blower Motor
The blower motor works intermittently.... Any ideas as to why? Thanks in advance.
Old Jun 4, 2025 | 08:26 PM
Common cause for blower motor issues are usually the blower motor resistor. But could be other issues. May want to dig up a wiring diagram and check that you get power where you are supposed to get power.
Old Jul 5, 2025 | 04:58 PM
monte07's Avatar
It's one of three things. Have a muliltimeter ser at 12v. Hook it up to the wires that lead to the register to the fans. If you see power fluctuation the hvack fan controller works then hook back up the register and do it again. If you see power fluctuate when you adjust the fan speed the resistance is ok then you know it's the fan. The register and the fan is a 5.4 or 6.5 mm bolt trying to find that socket is like finding platinum on the ground
Soundwave22
Sep 15, 2025 05:57 PM
biggsmittee
Mar 26, 2014 05:07 PM
raikel
Jun 28, 2013 07:03 PM
dominic
May 10, 2009 02:43 PM
MonteRosa
Aug 24, 2007 06:10 PM
