monte acting weird.
Old Sep 23, 2007 | 02:42 PM
FlynhghR's Avatar
Default RE: monte acting weird.
04, getting the car to run right if you have a post cat 02 sensor won't be easy. Some ppl have had success with 02 simulators, but it's not worth being illegal. As long as you don't have any coolant leaking in the exhaust,and aren't running overly rich, or have dead cylinders... you'll be fine. If you want some REALLY good info on how/why cats fail, go to http://www.car-sound.com/04basics/04failures.asp
Magnaflow's site has really good info, as they make the replacement cats and high flow ones.. ceramic or metallic core.
Old Sep 24, 2007 | 02:17 PM
GrandPaDave's Avatar
Thanks for the exellent link, I've bookmarked it.
Old Sep 24, 2007 | 06:09 PM
BLACK ATTACK's Avatar
Photobucket
Monte Of The Month -- December 2007
BUDDY, GET YOUR MONTE IN THE SHOP NOW! Your owner's manual will tell you, when your engine light FLASHES it means you have a SERIOUS problem and the car went into limp mode (Service) to save the engine!
Old Sep 24, 2007 | 09:10 PM
04 Intimidator's Avatar
ORIGINAL: FlynhghR
Don't need the O2 sensor. Once I get my programmer.... HOLY ****!!! I get it tomorrow!!! Anyway, I'll be able to delete the P420 code that brings up the check engine light.
I don't have to worry about it being illegal because in my area we don't have emission. =D Chalk another bonus for living in Wisconsin.
Plusit will free up some HP and possibly some KR. Sure their is a question about backpressure, but I think the Dynomax mufflers will still keep that in check at my HP levels.
Old Sep 24, 2007 | 11:34 PM
FlynhghR's Avatar
Well, Iowa's not emission restricted or tested either, but we DO have, from what I understand, a law that says you have to have the cat. converter in the exhaust. I mean, not that any cop is going to crawl under the car to have a look... but still it's possible to be fined for it... Plus, on that link I posted, they tested a civic (granted it was a 4 banger and N/A, but still) it gained 6 horse from going to a high flow metallic, and 1 more horse from going wide open. (no change in tq) Plus.. the car won't smell like ****. That, or it was 6 by ceramic, 7 by metallic, and no more gained by a "test pipe" as they call em. (straight pipe, no cat)
And you won't just be able to delete the code... I mean you'd have to do it all the time.. you will have to have the sensor eliminator... right?
I mean, to keep the car from bringing the code when it senses the exhaust not being correct.
Old Sep 24, 2007 | 11:47 PM
ORIGINAL: FlynhghR
No, the programmer actually lets you delete the code completely so even if the sensor is screaming that the O2 is out of spec the CEL will never light up. I think you are thinking of the OBD2 scanners that let you just clear the code. The programmers allow you to eliminate the code... or at least block the CEL from coming on if the code is going crazy.
Another thing the programmer does is you can eliminate the P300 code as well when you install a bigger cam. That way the light doesn't come on for engine misfire.
Dstevens
Oct 7, 2013 01:17 AM
the5schlueters
20
Apr 1, 2013 03:53 PM
ss4me
Aug 21, 2012 09:49 PM
zx3adamania
Jan 18, 2008 08:48 PM
Great White North
Mar 31, 2006 12:52 PM
