a moded pcm?.. yay or nay?
BUT, I modded my Monte heavy enough that I HAD to get a PCM tuned and had that code deleted at the same time. I worked with PCMforLess.com. Service was great and the PCM is working AWESOME!
I highly recommend a tunned PCM for extra performance. In the case of the tuned PCM for my 3.5L, it also did WONDERS for the transmission, which is the same 4T65-E that all of the later model Monte Carlo's use.
There are a few companies that can do this for you.
Just try to do this LAST in your modification lists (unless you are top-swapping and can't run the car without it, obviously you'll need to do that at the same time)
This^
PINKFLOYD_
15
Jan 24, 2010 11:44 PM
SirMonte34
Mar 29, 2006 03:18 AM
