knocking in the front end
Old May 27, 2011 | 06:13 PM
One Dark SS's Avatar
Default knocking in the front end
I can hear it and feel it a lil when i turn the stearing wheel from side to side (while the car is not moving) but it is louder and hits a lil harder when i turn and accelerate ( when the front end lifts)
my mechanic told me that it is probably the intermediate stearing shaft, but hasnt actually looked at it, anyone have a clue? i know, theres alot of a moving parts in there....
Thanks for the input!
Old May 27, 2011 | 08:35 PM
werewolf-odst's Avatar
my car used to do the same thing, sort of, and i took to a machanic and they repaired my " paseger side HUB ASSEMBALLY '', that may be the problem, but i may be wrong.
Old May 27, 2011 | 08:36 PM
Could be many moving parts in the front suspension. Bushings, bearings, loose anything.
Old May 27, 2011 | 08:47 PM
X 2 Hard to tell with out looking at car ?
Old May 28, 2011 | 01:40 PM
NovaSS369's Avatar
i was gonna say ball joints or tie rods, cv shafts...could be a lot of things my friend. hard to say.
Old May 28, 2011 | 09:52 PM
well, there is play in my bearing, start there, seeing as it needs to be replaced...
thanks for the input!
Old May 29, 2011 | 10:04 AM
milrlyt's Avatar
The first things I thought of were bearings or the CV joints. Both can go out relatively easily. Good luck.
Old May 30, 2011 | 12:08 AM
jdawgkemp's Avatar
In my own experience my 01 SS was doing the same thing. I tried changing the ISS still had the sound til one day we brought it in the shop, jacked up the front end and repeatedly shifted in and out of park. Found the noise coming from the half shaft...never changed it out though since the noise went away when the weather got cold. Noise still hasn't returned...*knock on wood*
Old May 30, 2011 | 01:48 AM
Curtis24682007's Avatar
I would say check your bearings or your cv axles. If it does turn out to be your cv axles then check your bearings while your at it because a bad cv axle can cause your bearing to go to. I had the same problem when I would turn or go over speed bumps, turns outs out I was missing my cotter pins in my ball joints. I put them in and tightened them up and I have not had a problem since.
Old May 31, 2011 | 07:22 PM
well the bearing has play in it, so that for sure is gone, or at least on its way out... its gotten to the point where i wont drive the car anymore till i get my new bearings in (ordered off ebay... cheapo, but as long as they last a year or two, thats fine with me ATM)
how can i tell if my shaft is gone bad? what symptons should i look for? the car is 11-12 years old (depending on when it was actually manufactured, its a 2000)
