6th Gen ('00-'05): Misfire
Old Dec 6, 2012 | 04:57 PM
nyislanders's Avatar
5 Year Member1 Year Member
Angry Misfire
Hey everyone, I know I haven't posted in a while but oh well.
I'm having a cylinder 1 misfire issue. I ruled out spark plug, wires, and the coil pack. What else can I look at to fix this? It's really bothering me.
Any replies appreciated!
Old Dec 6, 2012 | 05:06 PM
What motor does it have?....How many miles are on it?
Maybe possibly a bad valve in #1 or a collapsed lifter...
Bad wire, broken spark plug...improper gap...do a compression test...or a cylinder leak down test....
Old Dec 6, 2012 | 05:08 PM
It's the 3.8, around 108k miles. I already replaced the wire and the spark plug, but I'll look into the other things mentioned. Thanks.
Old Dec 6, 2012 | 07:25 PM
aussiek2000's Avatar
Injector. Have you checked compression?
Old Dec 6, 2012 | 07:45 PM
Have you taken the plug out and inspected it? If it's covered in coolant, failing head gasket would be my guess. If it's soaked in gas, you injector could be stuck open pouring in too much fuel. Could also be an injector NOT putting in enough fuel. The cheap way to test, swap the injector with a different cylinder.
Also, remember, replace the injector O-rings. They are cheap and at their age/mileage, re-installing used ones could create leaks.
Also, a vacuum leak could cause an issue.
Could be a bad plug wire (inspect for damage to the sheathing, signs of arcing).
Any other codes beyond the misfire code?
Old Dec 6, 2012 | 08:50 PM
No other codes besides the misfire code. Thanks for the replies everyone, I'll check those out and get report my findings.
Thanks again.
WickedxxClown
Apr 3, 2009 05:52 PM
raptorus1
Feb 27, 2009 08:19 PM
Dustin
16
Oct 12, 2008 10:13 PM
menaja19
14
Jan 2, 2008 09:21 PM
mloiselle20
May 1, 2007 04:58 PM
