message box
Old May 22, 2010 | 02:05 AM
02montecarlo's Avatar
Arrow message box
Ok I've got a question, I have an 02 ss and my mechanic just replaced my oil pan gasket and the low oil level message is still active..what gives is there a way to reset it or did he not do the job correctly, n also he just changed the oil at the same time..how do you reset the change oil message.
Old May 22, 2010 | 05:30 AM
...turn key on (dont start the engine)push gas pedal to the floor 3 times in 5 seconds that should reset it.
Old May 22, 2010 | 09:39 AM
saigashooter's Avatar
I would still check the oil level with the dip stick, if it is low, you don't want to ignore it.
Mine informed me it was low about a month ago, and after adding a half quart the sensor turned itself off.
owens91
24
Dec 27, 2013 02:09 PM
TGAbreu
Jun 7, 2007 08:32 PM
deadlifter
Feb 17, 2007 07:26 AM
schultzy
Feb 5, 2007 09:19 PM
montejass
Sep 21, 2004 11:29 PM
