man whats the deal
just noticed this
went to the car and was look in at this gosh darn AIC valve and i noticed this and i couldnt with the others cos they were plastic and this was metal, it got so hot that it discolored the metal now wth is going on here? lol
i fixed that sob
well yesterday it wasnt blistering hot so i decided to take 1 last crack at this problem before going insane. i started the car up and while it sat there puttering i started unhooking sensors and checking voltages ect... well i pulled out the IAT sensor and the engine picked up to rpm and ran smooth as butter so im like hmmm i pulled it out of the airtube and to my shock it showed the gross inefficency of my air filter. it was covered not only in dirt but also moisture. so i removed the CAI and reran it as a ram air system for the time being. i still cant belive that filter was lettign that much dirt and moisture into my car. shocked its been running at all....
RE: i fixed that sob
ORIGINAL: wiz kidd
where do you run your filter to chris?
glad that you found the problem though
VictoryRedSled
13
06-23-2013 07:34 AM
