Opinion Needed: Low Oil Pressure light keeps coming on
Old Aug 10, 2019 | 06:45 PM
ThomasB81677's Avatar
Default Low Oil Pressure light keeps coming on
I have a 05 Monte Carlo Supercharger. The past two weeks the low oil pressure light keeps randomly coming on. I have checked the oil plenty of times and just changed it, so it has oil. If I reset the oil life setting it goes away for awhile but comes back. The car is running fine and the check engine light is not on. I’m 99% sure it’s the oil life sensor or whatever it’s called. It’s annoying as hell though, I was wanting a second opinion on it. Is it the sensor or something else?
Old Aug 11, 2019 | 08:30 AM
Jeffs02rwdSS's Avatar
Your referring to two different things , low oil pressure and the life of the oil. If the low oil pressure light is coming on and you've confirmed the level is fine I would suggest getting a new oil pressure sensor. It's definitely possible the sensor is starting to fall nothing uncommon. If after you change the sensor and still have the same problem it would suggest a weak oil pump or a major mechanical issue. Good luck.
Metroboomin
Oct 13, 2017 11:11 PM
orthokneepa
16
Apr 1, 2015 10:19 AM
killerBee
May 18, 2013 08:30 PM
Randy Biron
Jul 14, 2012 08:07 PM
dogmanx
Nov 17, 2011 11:37 AM
