low oil pressure
Old Jul 19, 2014 | 01:43 PM
taemiddle's Avatar
Default low oil pressure
Hey guys. I have a V6 2001 Monty SS. My oil gauge from time to time says my oil pressure is low, then it goes back to normal. What could that be?
Old Jul 20, 2014 | 11:14 AM
Nightmagic11801's Avatar
some possibilities:low on oil. check your level. oil pump regulator valve not operating correctly, the oil pump may be worn out, you could have a clogged oil filter or strainer. or your gauge itself could be acting up all in itself. which could be caused by a bad wire somewhere. or your engine could be overheating. when was the last time you did an oil change? do you notice the engine overheating at all?
Old Jul 21, 2014 | 12:38 PM
taemiddle's Avatar
No overheating. I put oil in. Now hand stays in middle till i hit the gas. When i hit the gas it goes to 3 quarter line. Other than that everything is cool. No noises or nothing
Old Jul 22, 2014 | 07:28 AM
i would have your oil pump looked into
Old Jul 22, 2014 | 08:52 AM
owens91's Avatar
Another thing to look into is the oil pressure sending unit, theu go bad at times as well. When mines went bad there was oil everywhere. That don't happen all the time tho, still another strong possiblity
joe111599
Jun 10, 2016 07:01 PM
orthokneepa
16
Apr 1, 2015 10:19 AM
TMoney
Aug 18, 2013 02:37 PM
Randy Biron
Jul 14, 2012 08:07 PM
jed992
Aug 2, 2010 07:31 AM
