Leaking fuel filter
Hello. Replaced fuel filter in my 2000 SS two months ago. All was well until yesterday. Lots of fuel leaking out where filter nipple snaps into fuel line leading to gas tank. Is there some kind of gasket or fitting that goes into the fuel line where the filter nipple fits into it?
It's worked fine for the past two months.
ANY help would be greatly appreciated. Thank you!....scott
The nipple end has a flare on it to prevent leaks. The problem is probably the plastic tab around it that holds it in place. I would just get another fuel filter and replace it. The new filter comes with a new plastic tab. I would also check the fuel line to make sure there is no damage to it as well.
5th Gen ('95-'99): Fuel Break! Fuel in my vacuum line and air filter
Slamjunk
Sep 29, 2014 03:56 PM
JaxJim
Jun 5, 2012 12:47 PM
