Leaking fuel filter
Old Sep 4, 2010 | 02:53 PM
artlawton's Avatar
Default Leaking fuel filter
Hello. Replaced fuel filter in my 2000 SS two months ago. All was well until yesterday. Lots of fuel leaking out where filter nipple snaps into fuel line leading to gas tank. Is there some kind of gasket or fitting that goes into the fuel line where the filter nipple fits into it?
It's worked fine for the past two months.
ANY help would be greatly appreciated. Thank you!....scott
Old Sep 7, 2010 | 09:24 PM
seawolf18's Avatar
The nipple end has a flare on it to prevent leaks. The problem is probably the plastic tab around it that holds it in place. I would just get another fuel filter and replace it. The new filter comes with a new plastic tab. I would also check the fuel line to make sure there is no damage to it as well.
Old Sep 8, 2010 | 09:41 AM
artlawton's Avatar
Default Fixed it!
Hi. The flare end of the fuel line was damaged. I cut it off and attached a new one to the fuel line and it works fine. Thank you very much for your suggestions!.......scott
Slamjunk
Sep 29, 2014 03:56 PM
MJClemm
Mar 18, 2013 07:10 PM
JaxJim
Jun 5, 2012 12:47 PM
rockieg00
Feb 1, 2010 05:53 PM
Shasta
Nov 28, 2007 08:29 PM
