L67 issues
Old May 14, 2013 | 08:57 PM
oscar sanchez's Avatar
Unhappy L67 issues
ok i have a p1133 code that comes up every now and then, also i have throttle issues when i barely give it gas slightly revs up and down this also happens when i hit a slight incline if its a steep incline it downshifts which i know is normal but stops doing it. i removed the MAF sensor when i swaped the engine could this be causing it or maybe a bad pcm tune? please help
Old May 14, 2013 | 09:24 PM
nitehawkjcb's Avatar
P1133 is O2 sensor. I'd start with replacing that. And you're not running a MAF?
Old May 14, 2013 | 10:05 PM
The car is designed to run with a MAF sensor. Disconnecting it is a short-term test (as you will not get proper performance out of the drivetrain).
I think for starters, I'd put the MAF back and drive it a short while (for the PCM to re-adjust).
Old May 16, 2013 | 08:25 PM
whoops sorry removed MAF screen aka honeycomb screen, nitehawkjcb i remember you telling me to get a new 02 a while back i did and no dice bro issue still exists, new 02 sensor, i seen somewhere if you remove this screen (honeycomb) it meses up your MAF readings could this be causing my **** headache? what does removing your MAF do as far as diagnosing?
MPS 3.2
intense stage 1 tune
1.9 yella terra rockers
SLP headers
3inch DP
Dynomax 2.25 cat back
Walbro 255lph inline
Custom FWI
MSD coils
Autolite 103s
Old May 20, 2013 | 09:34 PM
so what could be causing this c'mon guys please help me out
Old May 20, 2013 | 09:52 PM
There are 2 oxygen sensors. You may need to replace the other. And if you remove the MAF and the issues go away, you need a MAF.
Old May 20, 2013 | 11:42 PM
ok so if i disconect the MAF and the hesitation stops its the MAF, but if it doesnt probably the O2 sensor/s right? ok ima try it out thanks guys wasnt sure about the whole MAF removal deal thanx...
Old May 21, 2013 | 01:03 AM
Correct.
Maybe. Could be TPS, IAC, or a plugged PCV also...
The MAF screen is another story. I wouldn't do it, I believe it helps with air flow, but check ClubGP I'm sure they've had some in depth conversations about it.
Old May 21, 2013 | 06:44 AM
03SSLE's Avatar
P0133 is triggered by slow circuit response of the bank1/sensor1 O2 sensor. The air/fuel ratio is not being adjusted correctly by the signal from the O2 sensor. Even so, it will usually not cause drivability problems. Several things can set this code:
Bad wiring
Exhaust leak
Air intake leak (downstream from MAF)
Defective O2 sensor
Defective MAF sensor
Old May 21, 2013 | 09:44 AM
xxfallen-comradexx's Avatar
Awaiting Email Confirmation
Might be a clogged catalytic converter
str3etgl0w
Sep 13, 2012 08:22 AM
RocknSS04
Sep 8, 2007 04:16 PM
chgs15
Feb 2, 2007 05:02 AM
04 Intimidator
Oct 30, 2006 12:11 PM
roadshoptuner
Aug 2, 2006 12:53 AM
