2001 monte ss with intermittent problem
Old May 21, 2013 | 09:54 AM
blldg187's Avatar
Default 2001 monte ss with intermittent problem
I have a 01 monte ss it has a strange problem and I am really needing help.
It runs and drive fine it has 176 k on it
And here is the problem when I am driving. it will just die it starts right back up and no more issues for days. Also if you are going down the highway the all the instrument lights will flash and the ding goes off then its fine. Also a intermittent problem .
Now yesterday I was going about 20 mile an hour accelerating and it was like the car died I looked at the gauges and the car was still running but real rough then it backfired thru the exhaust and if you gave it any throttle it did nothing. I then shut the key off and restarted it. It ran smooth but the engine was pinging when accelerating. I shut it back off and re started it and it ran fine no pinging nothing and couldn't get it to do it again
HELP !!!!
Old May 21, 2013 | 10:36 AM
03SSLE's Avatar
Welcome to the forum.
It sounds like you may have a worn ignition switch. When the contacts wear or become corroded/oxidized it can cause all kinds of gremlins - stalling, dash lights going berserk, non-operative accessories, etc.
Old May 21, 2013 | 11:17 AM
blldg187's Avatar
I replace the ignition switch this last weekend
scragun
Jun 17, 2014 04:10 PM
Trialsguy
Nov 30, 2013 10:50 PM
BIG AL 070
Dec 20, 2012 08:31 AM
ginniet
Jun 20, 2011 06:15 PM
White05LT
May 20, 2007 11:39 AM
