Key Fob ???
Old May 23, 2007 | 12:25 PM
ffej06montess's Avatar
Default Key Fob ???
I have a 2006 SS, and for some strange reason both of my remotes do not work anymore.
Does anyone have any clue why, or is it something only a dealer can fix.
It is not the battery, not a fuse.
Thanks
Old May 23, 2007 | 12:51 PM
Laserblue06ss's Avatar
Default RE: Key Fob ???
My 06 SS did the same thing when was only 2 months old.The dealer had to replace the receiver unit which is under the dashpad.They tried a reprogramming first,but when that didn't work,they had to order the replacement unit.I had to leave the car therefor a day.The service manager said it was a common problem.I beleive you will find many previous posts here on the topic.The receiver unit also will affect the tire pressure monitors as well.I have not had a problem since however.
Old May 23, 2007 | 12:52 PM
Thanks for the info!
Old May 23, 2007 | 02:01 PM
04 Intimidator's Avatar
I'd first check the user manual on how to reprogramm them... I know you do it through the radio. Check that first, then bring to dealer, unless you still have a warranty, then I'd just let them deal with it.
Old May 23, 2007 | 03:21 PM
omb76's Avatar
I have the same problem with mine also. It's actually at the dealer getting repainted this week so they are going to fix it while they have it. They also said that it was the receiver (which entails ordering a new receiver, antennea, and reprogramming the remotes). This also affects the tire pressure monitors which on mine go off about once a day. Mine never quit working all together, but the farthest I could be away from the car was about 5-feet after that they quit working.
Old May 24, 2007 | 01:49 AM
Mrrench's Avatar
Take to the dealer
They will replace the antenna
Will reprogram and update the unit and replace both fobs.
When they replace the fobs you will get one for remote start and the other will be a reg. remote.
Old May 30, 2007 | 10:09 PM
Any updates on this?
Old May 30, 2007 | 11:14 PM
FlynhghR's Avatar
I had that same thing done on my car, haven't tested the key fobs, but they seem to be working better, but I'll have to check their range. The night I got the car back from the dealer it gave me the tire pressure monitor system error, but I haven't gotten it since, so I'm thinking maybe the code didn't get reset from before the repair, and just happened to display. Was done for no charge.
Old Jun 5, 2007 | 11:29 AM
omb76's Avatar
Just had mine fixed today and it works great again! They replaced the receiver, antennea, and both remotes. Also, both of the new remotes will start the car.
I would say that those of you who have had this done and only have one remote to start the car now should go back and complain, there's no reason they both shouldn't work. You paid for this after all!
ffej06montess
Dec 16, 2010 10:01 AM
jeffrae
Feb 27, 2008 10:52 PM
Datafive0
Mar 12, 2007 02:29 PM
ralphtrent
Dec 24, 2005 01:01 PM
03SSdriver
Sep 16, 2005 10:43 AM
