just bought 2000 ss, alarm/horn no sound
Old Feb 15, 2011 | 08:25 AM
deezdrama's Avatar
Unhappy just bought 2000 ss, alarm/horn no sound
Just bought a 2000 ss yesterday. Noticed the horn is not working when i push on horn or when i set alarm. I checked the horn fuse and its fine.
When i hit the alarm button on keychain the lights flash and i can hear the horn relay clicking but theres no audible sound from the horn at all.
Would somehow resetting the alarm fix this or does it sound like the actual horn itself has gone bad? Any other ideas?
thanks in advance!
Old Feb 15, 2011 | 04:28 PM
Check the horns,there are two.
Old Feb 16, 2011 | 08:47 AM
If it's an aftermarket alarm, the potential exists that someone "cut" the horn lines and never put them back together.
Old Feb 16, 2011 | 09:11 AM
Jomao_o's Avatar
Check the settings on your stereo.
I'm not sure, but I think you can turn the horn off aswell as the light delay... just something to think into.
Old Feb 16, 2011 | 09:40 AM
Those settings would control a factory alarm/keyless entry (not sure if his is factory or aftermarket). But regardless, he states the horn does not work if he pushes the horn button on the steering wheel (between that and not working with the alarm, leads me to think the wire is severed/disconnected or as someone else stated, a possible problem with the horns).
Old Feb 16, 2011 | 10:03 AM
Jomao_o's Avatar
Ah Ok, Maniac, reason why I posted I was thinking maybe the settings in the deck and aftermarket were someone off setting eachother, i didnt read where the steering wheel horn wasn't working.
Old Feb 17, 2011 | 03:01 AM
deezdrama's Avatar
yes... Its the factory alarm system, the horn fuse is good and i found one horn behind pass headlight and its connected, is other hoorn in same general location somewhere?
I bought it from a car lot so was wondering if it was disabled and just need to turn it back on or something?
I just dont see 2 factory horns failing to work so think the problem is elsewhere
Chevy Kid
Mar 14, 2014 06:59 AM
00'MonteSS
Apr 28, 2011 12:59 AM
Spook
May 5, 2010 02:38 AM
mitch520
Jan 23, 2009 02:47 PM
mitch520
Jan 22, 2009 11:16 AM
