Horn Alarm
Old Jan 21, 2009 | 08:49 PM
mitch520's Avatar
Default Horn Alarm
When I hit the release button for the trunk either on the key or inside the car the alarm goes off and the horn blows until I hit the button on the key. Is there something wrong or is there a way to change this? Thank you
Old Jan 22, 2009 | 11:15 AM
sorcier11's Avatar
Default RE: Horn Alarm
I know on my '04 intimidator, if the doors are locked and I try to unlock the trunk, I get that too.
It's part of the built-in security system. Just make sure your doors aren't locked when you try to get into the trunk.
Old Jan 22, 2009 | 11:42 AM
also if you hit the trunk button, and wait a little bit of time, and then touch the trunk to open it the alarm will go off.
maybe that timer is running wrong?
I know on my car when i'm grocery shopping, i hit the trunk early and then walk over to the car, and then when i finally get there sometimes my alarm goes off.
Old Jan 22, 2009 | 11:43 AM
RickCoMatic's Avatar
I'd look in the Operators Manual for programming the Key Fob.
If my car is locked, I can't open the Trunk with the Remote unless I Unlock the car ... first. If the car is unlocked, the Trunk Opens and the Back-up Lights come on.
My Remote also has a Panic Button ... that sets-off the Alarm and flashes the Lights. We use it to find the car after the movie lets out.
Old Jan 22, 2009 | 12:32 PM
rj's Avatar
rj
When we first got the '03 Pace car my girlfriend goes to open the car door with the key FOB and opens the trunk instead.
Is this the same thing you guys are talking about???
Old Jan 22, 2009 | 09:12 PM
Is it possible you need to re-learn the remote key fob? I believe it's in the manual. I'll have to check. Or maybe a security setting that's mentioned in the manual also.
Something isn't right. I never use the actual key for neither the door or the trunk. I always use the remote fob. When returning to my car after shopping, I hit the button for the trunk before I unlock the door all the time. The alarm (horn) has never gone off for me.
I'll have to look up some info in the owners manual. I downloaded a PDF file version of the 2004 Owners Manual from GM's website.
Old Jan 22, 2009 | 09:26 PM
If you haven't already read the manual, here's what I found so far:
[hr]
[align=left]Content Theft-Deterrent[/align][align=left]Your vehicle may have the optional content[/align][align=left]theft-deterrent alarm system.[/align][align=left]With this system, a light on the radio will flash.[/align][align=left]This light reminds you to activate the theft-deterrent[/align][align=left]system. Here’s how to do it:[/align][align=left]1. Open the door.[/align][align=left]2. Lock the door with the power door lock switch or[/align][align=left]the remote keyless entry transmitter. The light on[/align][align=left]the radio should come on and stay on. If you[/align][align=left]are using the remote keyless entry transmitter, the[/align][align=left]door does not need to be open.[/align][align=left]3. Close all doors. The light on the radio will slowly[/align][align=left]flash once the system is armed.[/align][align=left]Once armed, the alarm will go off if someone tries to[/align][align=left]enter the vehicle (without using the remote keyless entry[/align][align=left]transmitter or a key) or turns the ignition on with an[/align][align=left]incorrect key. The horn will sound and the headlamps[/align][align=left]and back-up lamps will flash for approximately two[/align][align=left]minutes.[/align][align=left]When the alarm is armed, the trunk may be opened with[/align][align=left]the remote keyless entry transmitter. If you use the key to[/align][align=left]open the trunk, the alarm will sound. The power door lock[/align][align=left]switches are also disabled. You must use your remote[/align][align=left]keyless entry transmitter or your key to unlock the doors[/align][align=left]when the system is armed.[/align][align=left][/align][align=left]Arming with the Power Lock Switch[/align][align=left]Your alarm system will arm when you use either power[/align][align=left]lock switch to lock the doors while any door or the[/align][align=left]trunk is open and the key is removed from the ignition.[/align][align=left]The light on the radio flashes quickly to let you know[/align][align=left]when the system is ready to arm with the power[/align][align=left]door lock switches. The light on the radio will stop[/align][align=left]flashing and stay on when you press the bottom of the[/align][align=left]power lock switch, to let you know the system is[/align][align=left]arming. After all doors and the trunk are closed and[/align][align=left]locked, the light on the radio will flash slowly to let you[/align]know the system is armed.
[align=left]Arming with the Remote Keyless Entry[/align][align=left]Transmitter[/align][align=left]Your alarm system will arm when you use your remote[/align][align=left]keyless entry transmitter to lock the doors, if the key[/align][align=left]is not in the ignition. The light on the radio will turn on to[/align][align=left]let you know the system is arming. After all doors and[/align][align=left]the trunk are closed and locked, the light on the[/align][align=left]radio will begin flashing at a very slow rate to let you[/align][align=left]know the system is armed.[/align][align=left][/align][align=left]Disarming with the Remote Keyless[/align][align=left]Entry Transmitter[/align][align=left]Your alarm system will disarm when you use your[/align][align=left]remote keyless entry transmitter to unlock the doors.[/align][align=left]The light on the radio will go off to let you know[/align][align=left]the system is no longer armed.[/align][align=left]The first time a remote UNLOCK command is received,[/align][align=left]three flashes will be seen and three horn chirps[/align][align=left]heard to indicate an alarm condition has occurred since[/align][align=left]last arming.[/align][align=left][/align][align=left]Disarming with Your Key[/align][align=left]Your alarm system will disarm when you use your key[/align][align=left]to unlock the doors. The light on the radio will go[/align][align=left]off to let you know the system is no longer armed.[/align][align=left][/align][align=left]Passlock®[/align][align=left]Your vehicle is equipped with the Passlock®[/align][align=left]theft-deterrent system.[/align][align=left]Passlock® is a passive theft-deterrent system. Passlock®[/align][align=left]enables fuel if the ignition lock cylinder is turned with[/align][align=left]a valid key. If a correct key is not used or the ignition[/align][align=left]lock cylinder is tampered with, fuel is disabled and[/align][align=left]the engine will not start.[/align][align=left]During normal operation, the SECURITY message will[/align][align=left]be displayed after the key is turned to the ON ignition[/align][align=left]position. See Security Message on page 3-48.[/align][align=left]If the engine stalls and the SECURITY message[/align][align=left]flashes, wait until the light stops flashing before trying to[/align][align=left]restart the engine.[/align][align=left]If the engine is running and the SECURITY message[/align][align=left]comes on, you will be able to restart the engine if[/align][align=left]you turn the engine off. However, your Passlock®[/align][align=left]system is not working properly and must be serviced by[/align][align=left]your dealer. Your vehicle is not protected by Passlock®[/align][align=left]at this time. You may also want to check the fuse.[/align][align=left]See Fuses and Circuit Breakers on page 5-104. See your[/align][align=left]dealer for service.[/align][align=left]In an emergency, contact Chevrolet Roadside[/align][align=left]Assistance. See Roadside Assistance Program on[/align]page 7-6 for more information.
[align=left]FOB HORN[/align][align=left](Remote Audible Verification)[/align][align=left]This feature allows the horn to chirp when the remote[/align][align=left]keyless entry transmitter is used to lock or unlock[/align][align=left]the vehicle, or to program no verification.[/align][align=left]Programmable Modes[/align][align=left]Mode 1: OFF[/align][align=left]Mode 2: PARTIAL – One chirp for each remote LOCK[/align][align=left]command/no chirp for remote UNLOCK command.[/align][align=left]Mode 3: FULL – One chirp for each remote LOCK[/align][align=left]command/two chirps for the first remote UNLOCK[/align][align=left]command.[/align][align=left]Your vehicle was originally programmed to Mode 2. The[/align][align=left]mode may have been changed since then. To determine[/align][align=left]the current mode, or to change the mode, do the[/align][align=left]following:[/align][align=left]1. Scroll, using the SEEK PSCAN up or down arrows,[/align][align=left]until FOB HORN appears on the display.[/align][align=left]2. Press the 1 PREV or 2 NEXT button to enter the[/align][align=left]submenu. The current selection will have an[/align][align=left]asterisk (*) next to it. If you do not wish to change[/align][align=left]the current mode, you can either exit the[/align][align=left]programming mode by following the directions later[/align][align=left]in this section or program the next feature[/align]available on your vehicle.[align=left]3. Scroll, using the 1 PREV or 2 NEXT buttons,[/align][align=left]through the modes to change the current mode.[/align][align=left]4. With your preference displayed, press the TUNE[/align][align=left]DISP button to select. A chime will be heard to[/align][align=left]verify the new setting. The new selection will[/align][align=left]be displayed with an asterisk (*) for one second.[/align][align=left]If your vehicle has the optional content theft-deterrent[/align][align=left]system, the first time a remote UNLOCK command[/align][align=left]is received, three flashes will be seen and three horn[/align][align=left]chirps heard to indicate an alarm condition has occurred[/align][align=left]since last arming. See Content Theft-Deterrent on[/align][align=left]page 2-15.[/align][align=left]The mode you selected is now set. You can either exit[/align][align=left]the programming mode by following the instructions[/align][align=left]later in this section or program the next feature available[/align][align=left]on your vehicle.[/align][align=left][/align][align=left]ALARM (Content Theft Operation)[/align][align=left]This feature allows the content theft-deterrent system to[/align][align=left]be turned on or off.[/align][align=left]Programmable Modes[/align][align=left]Mode 1: ALRM OFF[/align][align=left]Mode 2: ALRM ON[/align][align=left]Before your vehicle was shipped from the factory, it was[/align][align=left]programmed to Mode 2. The mode to which your[/align][align=left]vehicle was programmed may have been changed since[/align][align=left]it left the factory. To determine the mode to which[/align][align=left]your vehicle is programmed or to program your vehicle[/align][align=left]to a different mode, do the following:[/align][align=left]1. Scroll, using the SEEK PSCAN up or down arrows,[/align][align=left]until ALARM appears on the display.[/align][align=left]2. Press the 1 PREV or 2 NEXT button to enter the[/align][align=left]submenu. The current selection will have an[/align][align=left]asterisk (*) next to it. If you do not wish to change[/align][align=left]the current mode, you can either exit the[/align][align=left]programming mode by following the directions later[/align][align=left]in this section or program the next feature[/align][align=left]available on your vehicle.[/align][align=left]3. Scroll, using the 1 PREV or 2 NEXT buttons,[/align][align=left]through the modes to change the current mode.[/align][align=left]4. With your preference displayed, press the TUNE[/align][align=left]DISP button to select. A chime will be heard to[/align][align=left]verify the new setting. The new selection will[/align][align=left]be displayed with an asterisk (*) for one second.[/align][align=left]The mode you selected is now set. You can either exit[/align][align=left]the programming mode by following the instructions[/align][align=left]later in this section or program the next feature available[/align]on your vehicle.
[align=left]TRNKJAMB (Trunk Jamb)[/align][align=left]This feature allows the content theft system trunk lock[/align][align=left]sensor to be disabled or enabled.[/align][align=left]Programmable Modes[/align][align=left]Mode 1: TRNK OFF[/align][align=left]Mode 2: TRNK ON[/align][align=left]Your vehicle was originally programmed to Mode 2. The[/align][align=left]mode may have been changed since then. To determine[/align][align=left]the current mode, or to change the mode, do the[/align][align=left]following:[/align][align=left]1. Scroll, using the SEEK PSCAN up or down arrows,[/align][align=left]until TRNKJAMB appears on the display.[/align][align=left]2. Press the 1 PREV or 2 NEXT button to enter the[/align][align=left]submenu. The current selection will have an[/align][align=left]asterisk (*) next to it. If you do not wish to change[/align][align=left]the current mode, you can either exit the[/align][align=left]programming mode by following the directions later[/align][align=left]in this section or program the next feature[/align][align=left]available on your vehicle.[/align][align=left]3. Scroll, using the 1 PREV or 2 NEXT buttons,[/align][align=left]through the modes to change the current mode.[/align][align=left]4. With your preference displayed, press the TUNE[/align][align=left]DISP button to select. A chime will be heard to[/align][align=left]verify the new setting. The new selection will[/align][align=left]be displayed with an asterisk (*) for one second.[/align][align=left]The mode you selected is now set. You can either exit[/align][align=left]the programming mode by following the instructions[/align][align=left]later in this section or program the next feature available[/align][align=left]on your vehicle.[/align][align=left][/align][align=left]CHIRP (Horn Chirp Timer)[/align][align=left]This feature allows you to choose between short or long[/align][align=left]horn chirp sounds when the remote keyless entry[/align][align=left]transmitter is used.[/align][align=left]Programmable Modes[/align][align=left]Mode 1: SHORT[/align]Mode 2: LONG[align=left]Your vehicle was originally programmed to Mode 1. The[/align][align=left]mode may have been changed since then. To determine[/align][align=left]the current mode, or to change the mode, do the[/align][align=left]following:[/align][align=left]1. Scroll, using the SEEK PSCAN up or down arrows,[/align][align=left]until CHIRP appears on the display.[/align][align=left]2. Press the 1 PREV or 2 NEXT button to enter the[/align][align=left]submenu. The current selection will have an[/align][align=left]asterisk (*) next to it. If you do not wish to change[/align][align=left]the current mode, you can either exit the[/align][align=left]programming mode by following the directions later[/align][align=left]in this section or program the next feature[/align][align=left]available on your vehicle.[/align][align=left]3. Scroll, using the 1 PREV or 2 NEXT buttons,[/align][align=left]through the modes to change the current mode.[/align][align=left]4. With your preference displayed, press the TUNE[/align][align=left]DISP button to select. A chime will be heard to[/align][align=left]verify the new setting. The new selection will[/align][align=left]be displayed with an asterisk (*) for one second.[/align][align=left]The mode you selected is now set. You can either exit[/align][align=left]the programming mode by following the instructions[/align][align=left]later in this section or program the next feature available[/align][align=left]on your vehicle.[/align][align=left][/align][align=left]ORIG. SET (Return to the Original Settings)[/align][align=left]This feature allows you to return all customization[/align][align=left]feature settings back to their original factory settings.[/align][align=left]To reset do the following:[/align][align=left]1. Scroll, using the SEEK PSCAN up or down arrows,[/align][align=left]until ORIG. SET appears on the display.[/align][align=left]2. Press the 1 PREV or 2 NEXT button to enter the[/align][align=left]submenu. SET ALL will appear.[/align][align=left]3. With your preference displayed, press the TUNE[/align][align=left]DISP button to select. A chime will be heard to[/align][align=left]verify the new setting. The new selection will[/align][align=left]be displayed with an asterisk (*) for one second.[/align][align=left]The original factory settings are now reset. You can[/align][align=left]either exit the programming mode by following the[/align][align=left]instructions later in this section or program the next[/align]feature available on your vehicle.
[align=left]FOB PROG (Remote Keyless Entry[/align][align=left]Transmitter Programming)[/align][align=left]This feature allows you to match the remote keyless[/align][align=left]entry transmitter to your vehicle. To match the[/align][align=left]transmitter do the following:[/align][align=left]1. Scroll, using the SEEK PSCAN up or down arrows,[/align][align=left]until FOB PROG appears on the display.[/align][align=left]2. Press the 1 PREV or 2 NEXT button to enter the[/align][align=left]submenu. BEGIN will be displayed.[/align][align=left]3. Press the TUNE DISP button to start programming.[/align][align=left]When the message PUSH FOB flashes, press and[/align][align=left]hold the LOCK and UNLOCK buttons on the[/align][align=left]first transmitter at the same time for 15 seconds.[/align][align=left]A chime will be heard to verify the transmitter[/align][align=left]is learned.[/align][align=left]4. Repeat Step 3 for each additional transmitter.[/align][align=left]The transmitter is programmed now. You can either exit[/align][align=left]the programming mode by following the instructions[/align][align=left]later in this section or program the next feature available[/align][align=left]on your vehicle.[/align][align=left][/align][align=left]EXIT (Exit Feature Customization Mode)[/align][align=left]This feature allows you to exit the vehicle customization[/align][align=left]programming. To exit do the following:[/align][align=left]• Scroll until EXIT appears on the display.[/align][align=left]• Press the TUNE DISP button to exit programming.[/align]A chime will be heard to verify the exit.
Old Jan 23, 2009 | 11:10 AM
rj's Avatar
rj
....... I never use the actual key for neither the door or the trunk. I always use the remote fob. When returning to my car after shopping, I hit the button for the trunk before I unlock the door all the time.............
Didn't Mr. space post on here about thieves waiting for people to hit their key FOB to lock their vehicles at the mall. They would use a programmer to grab the codes then use the information to break in to people's cars while they were inside the mall shopping.
Old Jan 23, 2009 | 02:47 PM
Here's a detailed answer on that from Snopes.com:
http://www.snopes.com/autos/techno/lockcode.asp
Chevy Kid
Mar 14, 2014 06:59 AM
deezdrama
Feb 17, 2011 03:01 AM
Spook
May 5, 2010 02:38 AM
mitch520
Jan 22, 2009 11:16 AM
steptoe
Jan 27, 2007 10:36 AM
