Opinion Needed: Intermittent vibration with clunking...
Old Oct 20, 2018 | 02:37 PM
KeFlucasJr's Avatar
Default Intermittent vibration with clunking...
I have a 2004 Monte Carlo 3.8ss non-supercharged. I am experiencing a vibration with a clunking sound coming from what seems to be the front driver side. Its off & on / rough or smooth at various speeds. I've change the hub assembly & the cv axle. The issue still exists. While making those repairs I inspected all visible rubber boots & bushings. The only thing that showed any damage was the boot on the outer tie rod end. There is a split. I stuck my finger inside & felt some grease but no grit or debris from what I could tell. When I turn the wheel while driving or stationary it is smooth with no clicks or clunks or any noise. I do know that because of the split in the rubber boot of the (outside) tie rod end, the tie rod end should be replaced. But, could that be the cause of the intermittent vibration & clunking while driving, or could it be something else?
I truly do appreciate all of your help, tips, advice & suggestions.
- Ken Flucas
Old Oct 20, 2018 | 09:40 PM
Question What about your Brakes and rotors,?
- Ken Flucas
What about your Brakes and rotors,? If you over tighten the Lug nuts on the wheels this will warp the rotors and you will get a vibration from that.
Lug nuts should be at 100ft lbs on the torque wrench.
Old Oct 21, 2018 | 02:24 PM
KeFlucasJr's Avatar
The brakes & rotors does not show any signs of damage or warping.
Old Oct 21, 2018 | 03:45 PM
Jeffs02rwdSS's Avatar
Might be worth to take a good look at the sway bar and the links. Good luck
ThomasB81677
Jun 17, 2019 08:26 AM
gtr25
Mar 10, 2016 10:28 PM
iMSeRiOuS
Mar 24, 2013 09:32 PM
rgant_19
May 9, 2010 11:16 PM
mksiler
Mar 24, 2009 07:55 PM
