Intermittent Starting Prob...any help?
Good Morning Guys. I have an '03 Monte Carlo SS, 3.8L with 101K miles. In the last 3 or 4 months, there have been 4 or 5 times where it just won't start, leaving my wife stranded - well at least for several minutes until it cranks over. When this happens, it will not click, crank - nada - but the lights are good, radio blares, etc... The battery is relatively new and no issues with the alternator.
What do y'all think it might be? Should I try replacing the starter? I'm not much of a wrench but I think I can do it if it would fix this weird problem (one of the ONLY problems this car has given me in 6 years BTW!)
I'd love anyone to chime in with their opinion.
Thanks!
Clarkster (newbie)
Thanks!
Clarkster (newbie)
i'm having same problem right now. after driving for 30 minutes, go back out to start it and no start! try a few times but after 10 minutes it starts like nithing wrong at all. it happened a couple times a few months ago and went away, now last 5 days ,happening again. hope we get a for sure remedy .
Thanks!
Clarkster (newbie)
Thanks!
Clarkster (newbie)
Thanks!
Clarkster (newbie)
Thanks!
Clarkster (newbie)
I took it to the shop on Wednesday and just picked it up last night, they replaced the shift control switch....part was $255, and an hour of labor to install as well as an hour to diagnose so out the door I paid $455 and some change.
My 03 Monte Carlo SS is doing it again!!! Grrrrrrrrrrrr!!! Every so often, it won't crank over. The lights, radio etc all work fine. Relatively NEW battery. It hasn't happened in over 3 months until again this morning. It was happening every couple of weeks or so last fall. An Ask Chevy mechanic suggested I replace the crank relay (located under the hood in the fusebox area). $11 part so I tried that. Obviously that's NOT the problem.
Someone else stated they had the same problem and it ended up costing about $500 for a shift control switch (see above). The problem is that it's an intermittent thing and as soon as it does crank up, it'll probably be fine for a while. Hard to detect WHAT it is when it's working OK. This is getting to be a PITA because it's my wife's car and she's been stranded at work a couple of times.
Any ideas short of going that $500 route? (That might not fix it either!)
6th Gen ('00-'05): Intermittent Starting issue
ddschneider1972
Feb 15, 2015 06:36 AM
scragun
Jun 17, 2014 04:10 PM
rgant_19
May 12, 2010 11:15 PM
01, 03, 2000, 2007, askchevycom, carlo, intermitant, intermittent, intermittently, monte, problem, replace, start, starter, starting
