Intermittent Blower
k ill try that, so you had the same things going on with yours as whats happening to mine? because when mine acts up, a few things happen. the cruise light comes on, the heater/air don't work, and the message center on the roof dont turn on, and it comes on a min or two after i turn the key on. but if i hit the top of the dash it comes on right away. one last question, how do you get the switch out is there any tricks to it? thanks for your help.
Now that I think back, I didn't take the switch out. I just disconnected the wiring harness/plug and sprayed it, as well as spraying the switch. It really wasn't too difficult to get to once you remove the lower dash pieces on the driver's side. I think I had to lay upside down in the driver's side to get to the harness, so depending on your size....
I only had problems with the blower and the info center. But since those 2 seem so unrelated, I'm not totally surprised that your mirror didn't work.
You are correct -- you only need to reprogram if you replace the ignition switch.
Jim
Jim
Xx-007-xX
13
09-09-2009 09:36 PM
White05LT
05-20-2007 11:39 AM
