Intake Gasket Part #'s
Hey everyone thanks for reading this message! I have a 1996 Monte Carlo with the usual intake leaking into the oil. I know that this has probably been asked before, but I was wondering which Fel-Pro part # I need to fix this problem. My VIN says "M" for the engine code.....I have the 3.1 V6. I phoned the local parts store and they show 4 different part numbers for 4 different designs......the GM dealer says I have "rolling rockers", I'm sorry if I said that wrong just I am not a mechanic:( If I have it right will the Fel-Pro part # MS98004T work to fix this problem? Or do I need a different part #?
Thanks again for your help!! |
RE: Intake Gasket Part #'s
yup, MS98004T and dont pay over 100 bucks for it...dont get ripped off on this...i'm in canada and i sell this for around 100 bucks...and if your in the states you should definetly be cheaper
speaking of intake gaskets. VIP said, when i went in for a compression test that i should replace my Intake gasket, im like what the? the car runs finenothings leaking to my knowleged. nothing wrong with my compression by the way.
but i was wonderinghow much it wold be to get replaced? 3.1 L v6. and labor included? |
you probably dont need to have it changed..he's just suggesting it before you do HAVE to have it done...because sooner or later you will...
