injector placement on fuel rail
Old Aug 27, 2014 | 09:26 AM
vikesfan's Avatar
egr works the same, just plug in the connector. even though they "look" different, they are the same specs, just plug in the connector and you will be fine.
Old Aug 29, 2014 | 06:57 PM
woodr004's Avatar
Default Guide question
Hi Jason,
It is moving along albeit slow. Today I worked on the throttle body and EGR. For the life of me, I could not see any difference in the two throttle bodies. So I cleaned up and used the one off of the 3400. The EGR was different, the 3100 has a bottom mount and the 3400 had the side mount. I took the 3400 throttle body over to the vehicle and the electrical connectors seem to be the same. Are you aware of any electrical issues, like wires crossed or something? If non I would be inclined to use the '05 3400 throttle body and not make an adapter like the guide says. What do you think?
Pat
Sounds like good and steady progress Pat!! That's great. Once it's done, I bet you'll enjoy some extra pep from a 3400 instead of the 3100!!
Old Aug 29, 2014 | 11:24 PM
l67ss's Avatar
Use the 3400 tb, its 4mm larger
Old Aug 30, 2014 | 07:09 AM
woodr004's Avatar
Default Sweet!
Thanks guys. I hope to have this in and running next Friday. Am I going to have any issues with the cooling sensors? I seem to recall something about two on the 3100 and 1 one on the 3400. I don't have the guide handy right now.
Pat
Overdose666
Apr 19, 2021 12:10 AM
LittleE
Apr 3, 2013 11:09 PM
apguy
May 24, 2012 01:46 PM
Shandley
Dec 12, 2011 03:29 PM
augi
Jan 25, 2011 10:03 AM
