6th Gen ('00-'05): Idling too high
Old Sep 2, 2018 | 09:33 AM
reaperclub3's Avatar
Default Idling too high
Car starts but idling around 3000 rpm. Gives me code po102 saying there’s a sensor problem with the mass air flow
Old Sep 2, 2018 | 11:46 AM
Jeffs02rwdSS's Avatar
Here's a couple of things you can try or check that might help you. Confirm there is no vacuum leak anywhere which would cause a high idle.. Spray carb cleaner around the air intake system( intake gaskets, throttle body, vacuum lines) if the idle goes down address that first. You can remove and clean the MAF with air intake or Maf cleaner , might help if it's dirty and giving false readings. Can also unplug the Maf and see if the idle returns to normal. Good luck
Old Sep 2, 2018 | 03:24 PM
Turned out to be air leak. Gasket in throttle body
AsTheDaysOfNoahWere
Dec 23, 2024 09:24 AM
pajama01504
May 1, 2019 08:04 PM
khel72
Sep 23, 2018 10:06 AM
babyjokerxxxxx
Mar 26, 2016 08:07 PM
tkatz14
Jun 8, 2010 09:01 PM
