Idle timing problem
Old Mar 23, 2008 | 04:47 PM
Enemyofreali7y's Avatar
Default Idle timing problem
I'm pretty sure it's my idle timing. I have an '02 MC LS, it's a great car, but one thing that bugs me is when in reverse or in drive on an incline, it will roll as soon as I let off the brake, making it hard not to gun it out of a downsloped parking space or slamming into that back of someone at an inclined stop sign. I wanted to know if there was a fix for this or if this was just common with all monte carlos. Thanks!
Old Mar 23, 2008 | 05:11 PM
RickCoMatic's Avatar
Default RE: Idle timing problem
What does the car rev at when its in gear and stopped at a light?
What does it rev at in Neutral?
Old Mar 23, 2008 | 05:18 PM
I noticed it stops at 500 RPM's or so at a full stop.
Edit: Actually, after checking it again, it runs 600 in park and drive, and in neutral, it fluctuates between 600-700 RPM's.
Old Mar 23, 2008 | 07:24 PM
mrl390's Avatar
Alot of cars do that. Most 4cyl cars do that because they lack enough torque to keep it from rolling backward. If your car is idling low then that would cause your car to roll backward. I know my 3.4L in my z34 idles at 1000 rpms when warm all the time and it never rolls backward. I dont know what the 3400 is supposed to idle at by 600 seems a little low to me. Does your car seem to idle rough at 600 or does it idle smooth. If it idles smooth then it probably is fine. You have to remember that your car is a heavy car with a small, low powered engine so you may just have to live with the problem. If you have problems getting started, just use two feet, one on the brake one on the gas. Keep the brake pedal pressed and start pressing the gas lightly enough to get your rpms up to about 1000 and let out the brake slowly.
Old Mar 23, 2008 | 07:37 PM
ORIGINAL: mrl390
It idles pretty smoothly. I think you're right, i may just have to adjust. I was just curious to know if there was something I could do. But thank you for the reply, it takes a bit off of my mind.
Old Mar 23, 2008 | 07:40 PM
mickey's Avatar
mine idels at around 900-1000. rpm's but i have the 3.8 not the 3.4
Old Mar 23, 2008 | 07:58 PM
Is there any way to change what RPM the engine idles at, taking it to a shop or not?
Old Mar 23, 2008 | 10:01 PM
2000LS's Avatar
its normal, almost all automatic transmissions will allow this to happen, varies by how much angle you are on, and the vehicle.
if you were able to idle it up enough to hold on an incline the car would idle down the road at 30mph.
Old Mar 23, 2008 | 10:38 PM
ORIGINAL: 2000LS
ohhh....don't want that
Old Mar 23, 2008 | 11:43 PM
rysZ34's Avatar
ORIGINAL: Enemyofreali7y
You weight over 3,000lbs and have wheels and let off from a brake on an incline and see what you do. There probably isn't anything wrong with your car, they all do it if the incline is steep enough. Some just do it easier than others.
Dam20735
May 23, 2013 04:09 PM
CaptianBoost
15
May 10, 2012 11:55 AM
97MONTEZ34
Apr 23, 2012 12:28 PM
vita
Oct 31, 2007 09:52 AM
instantlunch
Sep 30, 2007 12:12 PM
