help
Old Mar 24, 2008 | 03:29 PM
NIEL305's Avatar
Default help
when i press the gas my oil pressure gauge go up why?
Old Mar 24, 2008 | 03:38 PM
rysZ34's Avatar
Default RE: help
Because you're forcing fluid through the system. As long as the needle isn't buried past 80 psi you're fine. It should fluctuate some.
Old Mar 24, 2008 | 04:01 PM
RickCoMatic's Avatar
Default RE: help
Because the faster the Engine turns ... the more Oil the Oil Pump pumps. And, ... since the Oil Lines and Bearing Tolerances don't get larger ... it's harder for the Oil to get through those tight spaces ... so, there's increased Pressure.
And, ... as Martha Stewart would say: "That's a good thing!"
Old Mar 24, 2008 | 04:02 PM
kweef's Avatar
Default RE: help
martha stewart thinkgs that a rise in oil pressure is a good thing? lol did she learn that in prison as well
jaydflash
Aug 29, 2014 03:38 AM
cj702
Aug 20, 2006 03:20 AM
