Idle problem
Old Oct 5, 2013 | 03:21 PM
Harlan2012's Avatar
Default Idle problem
My 2002 monte kind of pulsates when idling. Any suggestions? Thanks in advance.
Old Oct 5, 2013 | 08:14 PM
l67ss's Avatar
Default hey
Likely iac or crank sensor
Old Oct 6, 2013 | 01:18 AM
Can be any list of items:
- Vac leak
- Old plugs
- bad sensor
etc.
If you don't have a CEL on, then I would check for vac leaks and then plugs next.
Old Oct 6, 2013 | 02:44 PM
Harlan2012's Avatar
Plugs and wires are brand new. What sensor could cause this? I was goin to clean the iac and the egr to start. Btw what is a CEL?
Old Oct 6, 2013 | 02:55 PM
Harlan2012's Avatar
Disregard the last question, there is no check engine light on. Just ABS and traction lights.
Old Oct 6, 2013 | 04:30 PM
ohara's Avatar
does it pulsate when you are driving and let off the gas? this could also be a sign of a dirty MAF. Worth the $8 for a csn of MAF cleaner (only use specified cleaner for the MAF or you will probably ruin it, as it is just a piece of wire with what looks like a small spring coil in the middle and is very fragile) I just replaced mine as it wasn't working properly, but the CEL light did come on in my car. All you need is a safety torx one size smaller than the T-15 and honestly about 10 minutes of your time to clean it. It wouldn't hurt to do it and may resolve your issue, while you are doing that check for any leaks along the intake hoses that you have access to (by that I mean any vacuum lines you see while the engine cover is off) look for any wear and tear(s)
Old Oct 6, 2013 | 05:28 PM
Harlan2012's Avatar
It does it only while idling. I jus changed the MAF sensor not to long ago.
97MONTEZ34
Apr 23, 2012 12:28 PM
infine0n
Nov 14, 2009 03:38 PM
Enemyofreali7y
Mar 23, 2008 11:43 PM
vita
Oct 31, 2007 09:52 AM
instantlunch
Sep 30, 2007 12:12 PM
