03 heater fan mystery
Hi all! I'm a little baffled that the heat control/fan speed switch in my 03 Monte works on the highest (5) setting, but the fan doesn't work at all on settings 1 thru 4. I checked the fuses on both driver and passenger side fuse boxes and fuses seem ok. Anyone else had this problem or know if I'm missing something? Any help greatly appreciated.
https://www.google.com/search?q=heat...&bih=680&dpr=1
Check the videos on this page link looks like a resistor issue.
I did a little more research and yes, I do believe the resistor pack is shot...thanks for your help!
mkenney
08-01-2016 08:27 PM
sparkyallen1
03-11-2010 11:48 AM
