6th Gen ('00-'05): I need help instrumentation lighting
Are you in auto mode or with the headlight switch pulled out? Have you turned the dimmer switch in both modes? No instrument lights but gauges work? Do your interior lights come on when the door opens and when the dimmer is turned all the way to the click? Removed and Replaced fuses? Could be a relay or bad switch.
PhoenixAZMC
Jun 16, 2012 03:39 PM
