How to force AC on
Old May 25, 2011 | 08:51 AM
fastback4's Avatar
I'm leaning towards less than 12 volts. Those AC clutch wires are very small and doubtfull they would sustain a 12 volt high amperage current without melting, but I'm still learning things you know.
Old May 25, 2011 | 11:41 AM
fastback4's Avatar
I've learned the votage to the AC clutch is 12 volts. I hooked up my AC gauges, started the car max AC fan high and ran a jumper wire to the compressor and the clutch kicked on. So I had to add 2 pounds of freon(gott'a have a leak) and my air got ice cold and my engine cooling fans came on. I pulled the jumper wire and the clutch released. I bypassed the ac pressure sensor and still no AC clutch on. I'll mess with the relays tomorrow.
Old May 26, 2011 | 09:43 AM
mplsmike's Avatar
Let me know what you findout, have the same problem with 99 3.1 and was told it could be the selector switch in the car being bad and really don't want to keep speding money on stuff that might not be needed.
Old May 27, 2011 | 07:13 AM
fastback4's Avatar
Do all the checks I've done to my AC system then if all check ok it could be you AC controll modual. I went to autozone and they "kindly" installed another modual and my AC compressor kicked on. A new modual is 57.00. I went to my salvage yard and for 5.00 i have another modual. The modual is located under the dash just to the right of the emergency brake mechanism.......Tom
Old May 31, 2011 | 07:20 AM
mplsmike's Avatar
Thanks Tom but there has to be more of a problem, I tried the defrost and the compressor and clutch kicked on so when i turned it to the A/C that started to work. Well thought I would put more refrigerant in so when i took the airbox and and hose off the throttle body the damn thing wouldn't work, hooked everything back up and it worked. Weird.
Old May 31, 2011 | 10:36 PM
fastback4's Avatar
So you're good to go? Everthing works? When you put on the defroster the clutch will engage. It's suppost to. Taking off the airbox and inlet hose has no value at all unless you removed the air temp sensor lead so maybe there is a loose wire or ground somewhere.
Old Apr 9, 2021 | 05:30 PM
jjohnson0130's Avatar
Ok what if you unplug the ac pressure sensor and then ac light goes out and won't come back on until you plug wire back on to ac pressure sensor
Old Apr 9, 2021 | 05:32 PM
Default 2006 monte Carlo 3.5 v6
Monte#3
Jun 6, 2019 11:34 PM
TexasDvlDog
Nov 3, 2014 02:54 PM
doorkid09
Jun 20, 2011 06:19 PM
jsamuel01
May 16, 2011 03:38 PM
Class04Monte
Apr 12, 2011 07:56 PM
