High & Low Beams always on.....
Old Apr 13, 2009 | 08:03 PM
Zubius's Avatar
Default High & Low Beams always on.....
After going through 40 pages I could not find any info, Sorry if this is a repeated question.
2003 SS. My "highbeam out" message came up, but when I check they are on. I pulled all the bulbs and they are good. While the car is running the highs & lows are on but the lows are very dim. When I pull the switch all go a bit brighter but not much. Does this sound like the multi switch or a more serious electrical problem?
Thanks!!
Old Apr 15, 2009 | 07:29 AM
sonin66's Avatar
try resetting the car by taking off the negative line to the battery
Old Jun 4, 2013 | 07:17 PM
owens91's Avatar
ive been looking all day for a solution to this, i finally found someone that is having the same problem as me, i hope that someone will see this and also chime in or by any chance you came up with a solution. (even though this is a really old thread)
svzpt71
May 11, 2015 06:30 PM
MonteCarlo579
Jul 6, 2014 11:46 AM
larryz
Apr 22, 2010 02:15 PM
puntar10
May 1, 2008 07:54 AM
mickey
Mar 20, 2008 06:15 PM
