No low beams
Old Jan 9, 2010 | 05:53 PM
larryz's Avatar
Angry No low beams
Hi. I have a 2004 Monte Carlo Supercharged Dale Jr. edition and I've ran into a problem. I have no low beams but still have high beams. I'm getting power to the plug that bulb goes into but still no low beams. Also, I have replaced the bulbs with brand new ones and both relay switches. I'm about to pull my hair out. Can anyone help? Thanks ahead of time.
Larry
Old Jan 9, 2010 | 06:02 PM
Enzo354's Avatar
STILL SLOW
Welcome to the forum, there are plenty of members here, hopefully a mod can move this thread to a proper section. Have you checked all of the wires to the lights, a ground wire could be bad.
Old Jan 9, 2010 | 11:04 PM
x2 on brock, check the ground, because if theres powering getting to them, it probably cant complete the circle because the ground was either knocked apart or is loose
Old Jan 10, 2010 | 06:09 AM
larryz's Avatar
thanks i will try playin with the ground, ya dont think it could be a dimmer switch
but im still gettin power, just tryin not to have to find that bad ground
Old Jan 10, 2010 | 06:31 AM
Hi Larry, & Welcome to the MCF
Below is a link that may help until one of our
Expert Tech Member's reads your thread question
and posts their comments/solution
Check back
Below is from a Chevy Impala with no low beams
http://www.sparkys-answers.com/2009/...-low-beam.html
Hope it gives you a few things to check
Good Luck
Old Jan 10, 2010 | 09:22 AM
larryz's Avatar
thanks i may try that next it's jus drivin me nutz
Old Jan 10, 2010 | 10:01 AM
yeah deff check your ground & ur switch
Old Apr 22, 2010 | 02:15 PM
KWJR86's Avatar
I have the same issue, were you able to find a solution?
svzpt71
May 11, 2015 06:30 PM
Zubius
Jun 4, 2013 07:17 PM
East
Sep 15, 2010 10:12 AM
puntar10
May 1, 2008 07:54 AM
mickey
Mar 20, 2008 06:15 PM
