hesitation, jerking, low power..??? :(
Old 06-04-2011 | 01:04 PM
NYGiantsfan's Avatar
Default hesitation, jerking, low power..??? :(
wats going on fellas, just wen i finish fixing one thing another things comes along..at least it gives me something to do lol..i noticed that sometime wen i drive off after a light or stop it hesitates and jerks a lil bit before it just goes...i run 93 on her all the time its an 02... 3800...i bought that small bottle of lucas fuel injector cleaner but the problem still exists...any thoughts?
Old 06-04-2011 | 01:16 PM
nitehawkjcb's Avatar
Clean the MAF, change plugs, wires, fuel filter
Old 06-04-2011 | 04:59 PM
milrlyt's Avatar
Transmission slipping?
Old 06-05-2011 | 11:58 AM
BIGAL131's Avatar
Why are you running 93 octane in your 3.8?? No need for that and it wont improve performance....just wasting your money on the gas....3.8 runs fine on regular 87 octane which it was designed for if your read your owners manual.
Old 06-05-2011 | 11:29 PM
no no slipping thank god, i cleaned the maf last week ill do the wires and plugs next, ive been hearing about how much of a pain they are to change the 3 in the back
Old 06-06-2011 | 12:29 AM
They're not that bad. People should stop exaggerating lol
Old 06-08-2011 | 12:37 AM
DerEin's Avatar
The first time I changed my plugs and wires I unbolted the motor mounts to shift the engine forward to better access the rear three (as something like a Haynes manual will tell you to do). The 2nd time I did not and actually found it to be easier. Just be patient and it wont be so bad.
I guess you aren't throwing any codes? Sounds like an early MAF sensor failure. That sounds like the issue with mine, doesn't feel quite like a full-on misfire but like a cylinder or two isn't giving all its got?
Old 06-17-2011 | 02:55 PM
05MonteLS's Avatar
That's true- In fact I think the only engine that requires 93 octane is the Supercharged 3.8.
Chefjared
03-21-2012 11:15 AM
el402
04-24-2011 12:48 AM
robc
09-04-2010 09:05 PM
ssnowhite
17
09-23-2009 08:18 AM
enibum
05-14-2007 09:25 PM
