hesitation, jerking, low power..??? :(
wats going on fellas, just wen i finish fixing one thing another things comes along..at least it gives me something to do lol..i noticed that sometime wen i drive off after a light or stop it hesitates and jerks a lil bit before it just goes...i run 93 on her all the time its an 02... 3800...i bought that small bottle of lucas fuel injector cleaner but the problem still exists...any thoughts?
Clean the MAF, change plugs, wires, fuel filter
Transmission slipping?
Why are you running 93 octane in your 3.8?? No need for that and it wont improve performance....just wasting your money on the gas....3.8 runs fine on regular 87 octane which it was designed for if your read your owners manual.
no no slipping thank god, i cleaned the maf last week ill do the wires and plugs next, ive been hearing about how much of a pain they are to change the 3 in the back
They're not that bad. People should stop exaggerating lol
The first time I changed my plugs and wires I unbolted the motor mounts to shift the engine forward to better access the rear three (as something like a Haynes manual will tell you to do). The 2nd time I did not and actually found it to be easier. Just be patient and it wont be so bad.
I guess you aren't throwing any codes? Sounds like an early MAF sensor failure. That sounds like the issue with mine, doesn't feel quite like a full-on misfire but like a cylinder or two isn't giving all its got? |
Originally Posted by BIGAL131
(Post 330337)
