6th Gen ('00-'05): Hesitation around 1500 RPM
Old Jul 26, 2018 | 07:07 PM
TheKnight41's Avatar
Default Hesitation around 1500 RPM
05 Monte Carlo SS 3.8L SC - 110K Miles
I'm having a weird & inconsistent hesitation. Usually around 1500 RPM and 90% of the time going uphill. You can feel the car jerk a bit when it happens, but on a flat road it doesn't happen as much. I just had my plugs changed at 103K. I was thinking it might be the Cat building up back pressure, but not sure. I plan on replacing it anyways with a ZZP Down pipe & Cat.
I guess the jist is, what are your guys' thoughts on the issue, & if you have the ZZP Down pipe, how doesn't preform and sound?
Old Jul 26, 2018 | 08:09 PM
SuperchargedMonte's Avatar
This is either an ignition or transmission problem most likely. How old are the plug wires? I had the same issue and it was a bad plug wire to cylinder #4 for me. Does the transmission shift smoothly?
Old Jul 26, 2018 | 08:29 PM
Jeffs02rwdSS's Avatar
I'm with SuperchargedMonte sounds like a plug wire , are they the original set ? A few other idea's might be fuel filter, air filter and brand of plugs or perhaps you cracked the porcelain on a plug or the gap on the electrode installing them Good luck.
Old Jul 26, 2018 | 08:47 PM
Plugs re new as stated about 7K miles ago. Trans shifts fine.
Old Jul 26, 2018 | 08:51 PM
Wires changed with plugs 7K miles ago. Filters were changed at my 100K tune up.
I don't think it's a trans. If it were a failing trans, it would hold gear and slam hard? Gear shifts are smooth. It's just a stutter going uphill at a certain RPM, rarely happens on flat ground, which is why I'm thinking my Cat or even MAF now that I think about it.
Old Jul 28, 2018 | 03:33 PM
Default *Update*
Car kept randomly stalling today. Figured I'd try something simple, unplugged my MAS and problems gone. Ordering a new one.
Old Jul 29, 2018 | 07:00 AM
Did you mean MAF? What brand did you go with?
BrandonStebing
Sep 25, 2018 08:31 PM
BrandonStebing
Jul 22, 2014 08:30 AM
blackz34
Nov 24, 2013 06:06 PM
Furder2010
Dec 30, 2011 12:23 PM
wwestbu1002
Sep 24, 2009 12:13 PM
