Hesitation
Old May 2, 2008 | 02:56 AM
Farfig's Avatar
Default Hesitation
Whats the most usual problem for hesitation?
My fuel pump was dying for a while, and I have a feeling the engine was running lean to long that I might have damaged the plugs. I changed the plugs and wires last year november, so like, 7 months ago. Could it possibly be my wires/plugs or something else?
Its been happening for about three weeks now. I've tried both regular, premium, and fuel stabilzers.
Old May 2, 2008 | 07:56 AM
DEI Monte SS 04's Avatar
Default RE: Hesitation
You did not say how many miles on car. A cloged fuel filter is possible,and cheap wires can break down that soon. If the wire breaks down it fowels the plug. Also a coil pack that is going bad can give hesitation. Is there also a backfire or just hesitation?
Old May 2, 2008 | 01:12 PM
Farfig's Avatar
I replaced the fuel filter when the fuel pump went, last month. And the car has 110,xxx kilometers. So around 68,xxx to 69,xxx miles.
No backfire. Just hesitation. And its worse under light accleration, where as under hard accleration it just doesn't seem to have the same power and is a little slow off the line.
Old May 2, 2008 | 01:15 PM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
Bad cat can cause loss of power also.
Old May 2, 2008 | 01:55 PM
GrandPaDave's Avatar
ORIGINAL: dustybird3
Yes, you are right there as a candidate for a plugged exhause system (cat).
Old May 2, 2008 | 02:04 PM
Definetly get cat checked
MetalDragon
Oct 5, 2008 04:38 PM
boakesb
Apr 17, 2008 08:23 AM
mickey
Nov 11, 2007 05:22 PM
enibum
May 14, 2007 08:25 PM
enibum
Mar 30, 2007 05:23 AM
