HELP PLEASE > My Monte Carlo has a weird message that i don't understand
Old Apr 19, 2015 | 02:50 PM
Jaidon_O's Avatar
THANK YOU !!! Had the same exact issue, worked perfect.
Old Aug 15, 2016 | 07:46 PM
My03SS's Avatar
Had the same issue with high beam out fast blinker. It was the ground wire from the previous post. Thanks a lot. I doubt the local mechanics would have found it so quickly.
Old Feb 19, 2019 | 07:06 PM
Apollos7's Avatar
Default Amazing
Amazing, I had the same problem. My ground wire wasn’t loose or broke. I snipped the connector off, crimped on a new one, and bolted it back on. Fixed everything. Thanks everyone!
Old Sep 1, 2019 | 05:34 PM
DDMARINE's Avatar
Talking Fast blinkers
This is the best forum around. Had this same problem repaired the ground and all my demons are gone thanks guys.
Old Sep 23, 2019 | 03:58 AM
avendo's Avatar
where is that ground wire?
Old Nov 20, 2024 | 07:41 PM
Jase's Avatar
Originally Posted by Monte Carlo Lover
I can switch between my high and low beams, and all my lights work except the fog lights!
I Had the same thing happen to my 04 Monte Carlo after changing fuses, and many other things I finally decided that I would change my high beam bulb again. Well one of the ground wire on the driver side headlight was not in the end all the way (the wires bolted to the fender). I clipped the end, put a new $.02 wire end on, then took out the bolt and the old end,put the wire with new end on, then bolted it back up. Fixed everything right up. No more blinkers on crack, or headlight high beam messages.
sparkyallen1
Oct 14, 2019 10:10 AM
bigmichaelcool
Apr 29, 2015 01:05 PM
LilSeanCB
May 14, 2011 10:40 AM
puntar10
May 1, 2008 07:54 AM
duvalrattler
Dec 10, 2006 09:03 PM
