7th Gen ('06-'07): wacky electronics
Old Nov 26, 2024 | 01:24 PM
carlo59's Avatar
Default wacky electronics
Hi follks, just a question my 06 Lt 3.9l Monte Carlo was running great until just recently, the issue that popped up was driving along she shut down and displayed a message about traction control. I disconnected the battery reconnected and she started and ran again, shut off then after 5 minutes started again with out battry disconnect ran for 5 minutes then stalled as i got to my house. Since then she will start up after a battery disconnect and run great but may shut off and may not however after the 1st start usually will crank but not start our not even crank. I had it on the OBD 2 tester checking control module voltage at one time and saw voltage drop off and the car shut off Any help as to this bring a BMC or a Main power relay issue would be helpful. The car will set a code P0690 with a message "ECM Power relay sense current high" BTW great site and thanks for any help you can provide.
MikeMcD1973
Sep 8, 2023 08:42 AM
MikeMcD1973
MCF Website Problems & Issues
Sep 7, 2023 06:33 PM
ThomasB81677
Nov 3, 2017 09:22 AM
Derron84
Jul 9, 2017 03:05 PM
noboatfred
Mar 10, 2013 11:09 AM
