Help please
Old Jun 8, 2014 | 09:14 PM
bigwill250's Avatar
Default Help please
Can any one tell me what the line is in this picture? the line with the white arrows pointing to it lower left . It also has a green cap on it and what would happen if it's not hooked up to anything.
File Type: jpg
Old Jun 8, 2014 | 09:53 PM
That is the vacuum line for your vacuum assisted power brakes. You will have a huge vacuum leave on the car causing things like bad idling and your brakes should not function properly.
Reconnect and you should be fine.
Old Jun 8, 2014 | 10:35 PM
bigwill250's Avatar
I'm not sure it go's. any way you can post a picture?
Old Jun 11, 2014 | 09:34 AM
vikesfan's Avatar
the white arrows are for your EVAP system, not the brake booster as mentioned above (i think he was looking at the red circle instead of the white arrows).
if its not hooked up you will get a code and slightly lower mpg and may run slightly rough.
Old Jun 11, 2014 | 10:14 AM
Ok I did not see the white arrows, just the big red circle.
As for the white arrows, vikesfan is right
Old Jun 12, 2014 | 05:54 PM
bigwill250's Avatar
Thanks Guys
chevyONmine
Aug 1, 2023 07:33 AM
86monte carlo
Feb 9, 2012 07:46 PM
77gp
Jan 7, 2012 02:04 PM
Emnasty600
Jul 8, 2011 07:17 PM
