help! No parking/tail lights
Old Mar 2, 2011 | 07:52 AM
montespython's Avatar
Default help! No parking/tail lights
99' LS front parking lots ok but rear inop.?? I checked the bulbs-ok. Anybody got a wiring diagram for this circuit? seems like it might be a wire/connection that feeds the back taillights...TIA!
Old Mar 2, 2011 | 08:43 AM
Slugger088's Avatar
Monte of the Month -- August 2013
I had this problem with my 95 z34. I think it was the wire/connection that you are talking about. All the cold and moisture over the years caused some corrosion somewhere there. I'll check my repair records when I get home later.
Old Mar 2, 2011 | 08:55 AM
Sparky-88's Avatar
Have you checked fuses? Did both sides go out? Are rear turn signals working or are all rear lights dead?
Bad electrical connection / corrosion at a taillight could be the problem, but that would likely affect one side or the other, not both at the same time.
Old Mar 2, 2011 | 12:00 PM
my guess would be fuses if its them all.
Old Mar 2, 2011 | 11:11 PM
Hey all, no all the rear light functions still work except for parking/running lights in the rear. The fronts work? Might be a wire somewhere, hence the need for a schematic...My wife was driving it cause the 2 yr old SERTA in our 03 SS just died so off to the dealer it went. this is a spare and she got pulled over because of it..lol...
Old May 1, 2011 | 03:47 PM
Problem was melted/corroded rear harness connector S400. all set!
shock081
Jul 14, 2010 09:00 PM
Mike03R1
May 26, 2010 09:55 PM
Mike03R1
May 23, 2010 07:18 PM
dougied
Mar 5, 2009 03:21 PM
Soulja
Sep 13, 2006 03:25 PM
