Help needed imediately!!!
Old Jul 10, 2011 | 01:00 AM
aceofmontespades's Avatar
all wires going to starter are on, tight and double checked.....that other forum helped little, didnt even think to check other fuse box.................nope all good, dammit.
Old Jul 10, 2011 | 07:24 AM
Did you try to start in neutral ? Is the shifter all the way in park?
It maybe a neutral safety switch problem ?
Old Jul 10, 2011 | 08:40 AM
mrl390's Avatar
The plug you pictured is for the washer fluid pump which is obviously non-existant by looking at your photo. Your problem could be the VATS. Try using the spare key if its in any better condition. If that doesnt help check out this site:
How to bypass the VATS system in a late model GM vehicle
Skeletal Crow
Mar 30, 2011 10:04 AM
Ulsterman
Aug 12, 2008 02:13 PM
04MonteLS
Aug 10, 2005 09:17 PM
Boost
Jul 1, 2005 03:10 PM
Boost
May 29, 2005 10:59 PM
