Help Monte Carlo running poorly
Old Dec 11, 2010 | 09:14 AM
jetaylor's Avatar
Default Help Monte Carlo running poorly
Hi,
I am a new member looking for help. I have a 2003 ss 3.8 that is losing power. It idles fine but falls down when I try to accellerate. It sounds like it bogs. It smells like rotten eggs and is getting horrible gas mileage now. I have changed the gas filter and air filter since it has been acting up. It appears to be getting worst. I first notced it about three weeks ago. It has 210,000 miles on it but has been maintained very well. I am the second owner. I have unplugged the MAF and cleaned it but no help. It seems to surge around 2100 rpm. It is getting to the point that it has a hard time on the hills in Maine now.It is a great car and in great shape so I would really like to resolve this. Could it be the CAT, it is the original? Is there any way to eliminate it other than replacing it? It does not get any codes that I can see with a OBD II. No CEL. Any help would be great.
Thanks
Monte in Maine
Old Dec 11, 2010 | 09:40 AM
Hi JeTaylor, and Welcome to the MonteCarloFamily.
Sorry to read that you are having a prob with your Monte Carlo.
It sounds like it's a bad `Cat they are known to clog,
especially with 210K miles.
Check back on your thread questions later & see what our
Expert Tech member's post/suggest on your `problem,
and the best solution.
I'm surprised it's not throwing codes
Wish you good luck & I hope that our member's can help.
Old Dec 13, 2010 | 12:02 AM
nitehawkjcb's Avatar
It's probably the cat. You could gut it, but that's illegal in many places. You probably need to buy a new cat...
Old Dec 13, 2010 | 12:14 AM
LXRASKAL's Avatar
Yeah illegal in 48 states including california(don't know the other state) if you get diagnosis and the po420 pops up then thats it, should not be more than 250$ to fix. Good luck and be patient
anthony_8606
Mar 18, 2021 02:29 PM
Nismosr20
Apr 24, 2014 11:47 AM
jimbol1955
Nov 30, 2008 06:16 PM
mj_duffy1989
Aug 17, 2007 02:28 PM
