Help identifying part
Old Dec 31, 2009 | 11:54 AM
lostcausenjtown's Avatar
Default Help identifying part
I have a vacuum leak that needs to be closed up so I can pass state inspection. I know the vacuum leak is the cause of my check engine light because it did not show up until I broke that plastic vacuum line. I am attaching a picture with the part that I need identified. The red arrow in the blue circle indicates the part that is giving me the problem. Is there a way to seal that rubber part or just replace it. Please help. Thanks in advance.
Old Dec 31, 2009 | 01:32 PM
nemesis's Avatar
2009 Monte Of The Year
duct tape it! didn't you ask about this before? any auto store will have different plastic fitting in a package you can for under $5 grab it and also get couple ft. of vaccum rubber hose. auto zone and pepboys sell them by the foot.
there's couple way you can fix it. find the right fitting in the package and reroute the whole vaccum lines or cut off few inches where the leak start and fit the rubber hose over the existing vaccum line. make sure to use zip tie to keep it seal tight. the original vaccum line is hard plastic just make sure if you do cut it it's a clean cut.
is there any junk yard in your area cuz any 3800 N/A should work.
00-05 mc
97-04 regal
00-05 impala
97-03 grand prix
Old Dec 31, 2009 | 03:52 PM
00-05 mc
97-04 regal
00-05 impala
97-03 grand prix
I asked about it when it first happened and followed the advice about the connectors and tubing. Those were the ones that are in the pic. It works but now the leak is causing my check engine light to pop on. I posted again because I have all of the right connectors and what not but the rubber piece that they go into has a crack in it from me trying to remove the broken pieces. This is the source of my leak. I am going to try and fix it on Sat because I have to change the wheel hub anyway. I was just seeing if anybody had any other ideas.
HiiiTek
Aug 29, 2014 09:20 PM
davidcope
Aug 17, 2013 06:44 AM
kelso
Nov 18, 2012 05:17 PM
AtomicPunk
Aug 27, 2011 11:55 PM
Brubaker
May 5, 2010 04:35 PM
