help with codes please!
Old Jul 28, 2013 | 09:30 PM
Fabman's Avatar
Default help with codes please!
2002 3.8 monte SS I have a few codes but dont know how to go about fixing them!
P0134 O2 circuit no activity detected bank 1 sensor 1
P0135 O2 heater circuit bank 1 sensor 1
P0140 O2 circuit no activity detected bank 1 sensor 2..
Ok bank 1 is the side of the motor with cyls 1 3 5 right? Does no activity mean the sensor isnt working? Im oldschool new to all this modern technology! Thank you for any suggestions.
Chad
Old Jul 29, 2013 | 02:13 PM
john213la's Avatar
Causes
The causes for a P0140 code are fairly few. They could be any of the following:
Causes
A code P0135 may mean that one or more of the following has happened:
  • O2 Heater element resistance is high
  • Internal short or open in the heater element
  • O2 heater circuit wiring high resistance
  • open or short to ground in the wiring harness
Causes
A code P0134 may mean that one or more of the following has happened:
  • Bad O2 (oxygen) sensor
  • Bad heater circuit in the O2 sensor
  • Wiring or connector to the sensor frayed / broken
  • Blown heater circuit fuse
  • Holes in the exhaust system
  • PCM failure
i hope this helps...
Old Jul 29, 2013 | 08:27 PM
Fabman's Avatar
Ok well the heater circuit fuse was blown, replaced that an ordered O2 sensor. Thank you for the info!
Old Jul 29, 2013 | 10:10 PM
FYI - It's recommended you stick with a Delphi or AC Delco O2 sensor. Some issues have been noted in the 3800 community with BOSCH and other O2's.
Val1970
Oct 16, 2016 12:19 AM
Henderson21
Jul 26, 2014 03:37 PM
MonteMan92
Apr 20, 2012 07:28 PM
mdfan
Dec 23, 2010 02:10 AM
djplayap
Aug 1, 2007 09:54 PM
