Help?
Old Jun 26, 2013 | 07:23 PM
Harlan2012's Avatar
Default Help?
I was looking into mods and stuff. And i seen where i can put a bigger pulley on and a water pump under drive pulley. I also seen somthing about hubs. Would both these pulleys require hubs? Not to sure on this stuff. Thanks
Old Jun 26, 2013 | 09:53 PM
turbo monte's Avatar
What year car..... we need more info!!
Old Jun 27, 2013 | 06:43 PM
Harlan2012's Avatar
2002 monte ss 3.8
Old Jun 27, 2013 | 07:38 PM
OK first off you get smaller sc pulleys to make note boost to male more power. But you can't just drop pulley sizes without doing supporting mods or you will grenade the engine. There is a awesome thread here search general mod plan. A lot of good reading on how to mod.
Old Jun 27, 2013 | 08:42 PM
Harlan2012's Avatar
Yes turbo i kno i would have to get a diff throttle body, plugs, tstat etc..but my question is if i order the pulleys do i need to get their "own" hub for both of them or wht? Im a lil confused
Old Jun 27, 2013 | 09:15 PM
you can either buy press on pulleys or buy the modular pulley hub with modular pulleys for the sc. the water pump under drive pulley bolts to the water pump. i would either let the water pump pulley alone or buy a electric water pump if it were me. the alternator pulley is press on as well but for the minimal gains i wouldnt bother with it either.
jaydflash
Aug 29, 2014 03:38 AM
cj702
Aug 20, 2006 03:20 AM
